This Post is VERY Graphic and not for the weak. Proceed at your own risk. I do not take responsibility for anyone getting sick to their stomach after viewing this.
It pains me to make this Thread, but I wanted to pass along the information and see what questions I could get answered.
BACKGROUND:
At the beginning of October (2016), we headed out on the boat. It was me, my wife, my son, my daughter, and two of my son's friends. We rode around with no issues that morning, then proceeded to a snorkeling spot out in the Gulf of Mexico. We anchored up there, in 20 feet of water and snorkeled for a couple hours. Water was clear. Only thing would be some jellyfish. Got ready to leave and starboard engine wouldn't start. It would turn over without issue, just like normal, but wouldn't fire up. Port engine fired up no problem.
I tried all the safety switches and lanyard. Still wouldn't fire. Fuses were good too. I know my battery was good as well. I keep extra spark plugs on the boat. Pulled all the plugs. They looked normal. Replaced with new spark plugs and still would fire up.
So my plan was to pinch the cooling line and head back on one engine. Unfortunately, I didn't have anything specifically for pinching the line. I ended up using a vice grip, but it had the round clamp. So I used the END/TIP of the vice grip to pinch the middle of the cooling line. After I clamped it, it looked closed off to me! The cooling line was flat!
So we returned on one engine. Still didn't run but about 5mph back. Speedometer didn't even register. My intention was to go faster, however, it wouldn't get on plane for some reason. I know I've run it on plane on one engine last year (had fishing line caught in the impeller). Didn't have a problem getting on plane last year. Not sure if weight in the boat played a role. It was so strange, I videoed it. I can upload the video if needed to explain.
Anyway, I get back home and the engine still won't start. Turns over just fine. About 1 1/2 weeks go by before I can get the boat to my mechanic. Won't even turn over now. Port engine still fires right up. He pulls the spark plugs to do a compression check.....spark plugs are corroded. What?? The plugs are new and never ran after I installed them. So he pulls the engine and salt water has gotten into the top of my engine. The engine is now seized!
So now he's working on getting it unseized. The engine was still in such good shape, that no salt water leaked passed the pistons. No water in my oil. Dadgummit! But now he's got to replace and rebuild parts. I'm meeting him soon to see exactly what parts I am going to need and what parts he says are still good. Not gonna be cheap either. For now, he says the block is good, but will need new pistons and rings. Also has to work on the valves.
Although I felt very confident I pinched the hose correctly, there is no other explanation as to how the salt water got in there.
Curious what you guys would suggest and what anyone else has done in a similar situation.
Here are some pics he took after pulling the head off.
And for a better explanation of the vice grips...Here is a SIIMILIAR pair like I used. But I did not put the hose where the nut is here in this photo.....
I pinched the hose with this area.
Anyway, I'm going back to the bar to drown my sorrows....
Yep. That's where mine was located. It right at the base of where one of the head bolts is located. I discovered mine after having repairs done on a stuck valve. It's my belief that the crack was probably always there and whether or not mine was leaking or not, it went unnoticed until the head was retightened (a couple of times for other reasons). Each time, the leak got worse. I'm pretty sure that there's a defect in either the casting of that area of the block, or that the threading of that hole wasn't done properly and the head bolt blows out the bottom when torqued.Thanks for the suggestions guys! @bronze_10 good thought but not the pee hoses, they are all forward of the center floor section and would drip into the forward bulkhead section where the fuel compartment and floor drain is located. @CrankyGypsy I get a little plug blow-by as well. It will pool a little on top of the plugs but no leakage into the aft bilge, which normally stays bone dry. @itsdgm my suspicion (and fear) is in line with your photos. That is where I have been sniffing but couldnt quite make sense of where exactly to look and orient myself. I used a light And mirror to thoroughly inspect the exhaust and blocks. Port turned up free from any smoking guns; but look at what I see on the starboard.
The camera angle is oriented on an angle (hard to hold); but do you see what I see?
14 steps..... you have number 6 twice! lolThanks a million! This forum is awesome. There is a small crack there and based on the deposit trail, I definitely feel this is the source of the water from yesterday's post oil change run (with a perfectly cleaned engine bay floor). I love the paper bag idea to confirm it is the only source. It is hard to say from others' experience with this how long it took to ultimately reach a "gotta pull it/hard failure". I knew the water was not normal for my boat. It was something that just recently started happening more than once.
Soooooo, what now? It still runs great. No water in oil yet. I am kicking myself for forgetting my compression set yesterday. Even though I crushed the gaskets on a new set of plugs, I am thinking it would be a good idea to check compressions. I am curious why welding didn't work and if it is truly a waste of time. I really do NOT want to build an engine. Heck I dread even having to pull it.
A logical game plan???:
1. Head back to the lake (borrowing a buddy's old laptop to run YDS)
2. Tape down paper bags under engines and on floor (possibly duct tape a mirror by the problem area)
3. No wake it out of boat launch area, pause and check for any drops (results from idle power)
4. Plane up taking it easy and getting the engines up to temp
5. Stop and check for water leak track (results from cruise power)
6. Hook up yds to starboard and learn what I can.- record (this will take some homework)
6. Check oil for water contamination (old oil just removed was fine-yay!)
7. Pull starboard plugs and check compressions -record
8. Reinstall plugs (careful on torque since I already crushed the 1/2 turn gasket)
9. Start engine and watch for check engine warning. (Confirming it works post maintenance before touching the other engine)
10. Hook up yds to port (had a few check engine events last two outing that always go away when restarting)-record (hopefully nothing!)
11. Depending on time and YDS info, run compressions on port.
12. Remove paper, dry floor, start up both, confirm no issues/warnings then run for 15 or possibly 30 minutes straight at normal cruise for a timed leak rate measurement.
13. Back to ramp with a better understanding of what may need to be done.
Is it a bad sign I came up with a 13 step process?!
