subysti
- east Longmeadow Mass
OK here is what I've found today. Both batteries charged overnight and charger says they are fully charged. Starting battery is at 12.9VDC and house at 13.4VDC. Not sure why starting battery is at 12.9 but I have a call in to the Prosport people. I'm guessing its either because its new and needs a few charge cycles to accept a full charge or the charger is set to charge the starting battery to this voltage. The leads on the charger are specific to what battery they go to. stupid me though a forgot to check the readings on the conext screen. After a couple hours of running the stereo and couple items the house battery is at 13.2VDC and start is at 12.91. Leap forward a few more hours and the stereo has been running for about 6 hours now and I inflated a couple large towables. The house battery is at 12.2VDC and the start is at 12.9 VDC. hasn't budged. The conext screen says sys battery at 12.2 and aux at 12.2. I check them both again and start is at 12.9. I even started both engines for giggles to see if anything changed on the screen and they both still read 12.2. I'm thinking there is an issue with what is displayed on the conext screen, it seems to only be seeing the house battery. I called Yamaha tech support to see if there was something I was misunderstanding in the way it reads or works on the screen but they had no clue and said I need to bring it in to my dealer. I did check my manual again and on page 45 it states that the sys display should be the starting battery voltage and the aux should be the house battery. If there are any other people seeing this and can verify with a meter what is on their batteries compared to the display there may be an issue with the new boats. I know a couple others have mentioned something similar.
