Jongottschalk
- Pass Christian MS
- 242 Limited S E-Series
Have of course searched threads and no of the issues but can't seem to find anyone with similar issue. Bought the boat this Spring and first couple of times out no issues. Then I noticed my bluetooth would disconnect and at first thought it was my phone but have pin pointed it to when I throttle down my bluetooth disconnects. Not sure if it is harmonics or something going on with voltage etc but boat is running and showing 14.3 on both batteries underway and 12.3 after parked for a while.
I also have noticed my touch screen I can't touch in the middle of the screen and calibrated and actually made it worse. At the same time the BT started acting up I started getting ER flashing every 3-4 seconds on speedometer. Control launch and GPS pass works well once in a while but most the time throttle is blipping off everytime ER comes up. I know these issues from reading may be tachs, GPS module, or display itself but find it odd the bluetooth and all this happened on my 3rd outing and tend to think it is probably display.
THe other issue I noticed is gauges are fogging up once boat is warmed up and out for a while. I am going to pull them and drill some holes to vent it quicker but really hoping someone has seen the exact same issue so can pin point where the problem is.
