Delta Hop
Hello All. Recently, my 2019 Yamaha AR240 came up with the Communication Error: SPU25-15, Joystick and Depth Transudcer and GPS error. Subsequently displayed an "ERR" on the home screen where speed, water temp and compass were lost. After some research on the forum, it looked like it might have been a lose connection on one of the battery switches. I checked the start battery switch and noted that a connection was loose. I disassembled the battery switch and snugged up all of the connectors. Lo and behold, it fixed the problem. No more problem with the Communication Error or intermittent alarms that need to be silenced. HOWEVER, the problem is now all of the media has a lock icon next to it (e.g. FM, bluetooth, radio, Aux etc...). Connext is showing that the media is turned off. But, when I press the on button, it does not turn any of the media on, although the screen is responsive to being touched when I press turn on. I can turn the radio on from the swim deck but the connext screen still shows that all the forms of media are locked. I double checked my batteries and I do not see any unconnected grounds that may have been missed. Interestingly, when I had the radio on, if I press the "turn on" button, it sounds slightly like it is transmitting hum as though there is a missing ground somewhere. Has anybody experienced this before or any thoughts on how to approach this?
