- Lake Ray Roberts, Texas
- Boatless
- NA
- Other
- NA
What some dealers consider first service is different than others. The manual says you don't have to replace the oil filter, but most would recommend. Same with the spark plugs, remove, clean, inspect, gap, replace...but most dealers would also recommend if your removing them, to just replace them, especially on the MR-1 engines, because those plugs are fragile. Most of us use anti-seize on the spark plug threads and also tighten 1/4 to 1/2 turn past hand tight and disregard the torque wrench settings, because we used anti-seize on them. So the dealer charges can also vary because they all don't do all the same work. If you have them winterize it, your really going to get raped, because there is nothing to do to a Yamaha besides blowing out the water, cleaning, removing everything from it, stabilizing the fuel.
