misnMT
- Houston SW Burbs
- SX
I have the boat (2010 SX240) for 4 years now. I am not sure how long this crack has been there. I noticed it when putting in new impellers and wear ring housing. It’s about the size of a quarter and side does move a little when pushed on relative to the other side of the crack. I think you can even see in the pic that there is some overlap where the two pieces meet. You'll have to zoom in to the pic to see it.
As an aside, I don’t recall an impact and is an inside corner like that a stress point?
I’ve done some research and based on the size, it doesn’t look like I need to fiberglass it. I’m leaning toward Dremeling out the crack, fill with epoxy, and then gelcoat.
Thoughts?
Thanks, Brian in SE Texas
Thoughts?
