Cut 12" sub into yamaha 195?
Cainon01
Western Washington
195S
I want to cut a 12" wetsounds sub into my 195s. Has anyone here done or seen it done? I think it would look super good in the passenger side helm facing the passenger. I am very reluctant to do it and then find out about a fatal flaw. Im not afraid to cut my boat though, I have already added 8" revos to the cabin area. Any advice would be great thanks!0725201926.jpg
jdkaeser
Cincinnati, OH
195S
My bet is that access door will rattle like crazy and drive you insane! I watched videos of another members install and his is in an enclosure in that compartment and it rattled in the video. You don’t want to have that rattle like a hoopty in the ghetto. I should know, I hear it every time I get gas in my neighborhood! 😉
steveinmd
195S
I read a lot of comments with disappointment running free air subs.
Cainon01
Western Washington
195S
Yeah, that is probably what would happen. Kind of wish it did not have that access door. My old t-bird had trunk rattle something fierce but I couldn't hear it in the cab lol.
adrianp89
Tampa Bay, FL
252SE
I loved my pair of free airs in my 210. Pretty happy with the single on my 252. It depends on your expectation. They are perfect for blended full sound, not so good for vibrating the boats around you.
Cainon01
Western Washington
195S
Yeah I'm just trying to add a little more deep sound. Some songs just need that boom to play correct. Were they just mounted to the fiberglass completely free air or did they have a very ported enclosure?
jacoviii
Independence Mo
255XD
We had a pair of free air subs in our "18 242x it sounded great and I'm a bass head. big thing is to have the EQ/ crossover set properly.
adrianp89
Tampa Bay, FL
252SE
Essentially IB (Free-Air) is a very ported enclosure, at some point air escapes. They were just mounted to fiberglass with a backer ring for support.
1BadTundra
212X
I just did a 10" in my storage compartment, as soon as you close the hatch door, it muffles the sound terribly. My thought is, cut the hole in the fiberglass, use 5200 and some squeeze clamps to secure a "truckbox" to the backside. When it dries, drill through the fiberglass straight into the box. That will hold everything in place and a tight joint will be sealed pretty good.
FX195
Bradenton, FL
I put a 10" IB in my helm, it did flex alot until I reinforced the back inside with wood. Sounds great, no flexing, no rattles.
platinum00
AR195
FX195.. which JL is that m3 or 6?
Cainon01
Western Washington
195S
Well thats promising! Do you not have a door on the helm or am I seeing the picturewrong?
Cainon01
Western Washington
195S
I wondered about something like that. Would also protect the sub.
FX195
Bradenton, FL
2018 did not come with a door/storage on helm.
kgower
Buford, GA
222SE
I want to cut a 12" wetsounds sub into my 195s. Has anyone here done or seen it done? I think it would look super good in the passenger side helm facing the passenger. I am very reluctant to do it and then find out about a fatal flaw. Im not afraid to cut my boat though, I have already added 8" revos to the cabin area. Any advice would be great thanks!View attachment 172113
I added an additional pair of stock 6.5" speaker's mid cabin. Placed a 10" sub in port side helm.
Extremneon
SX195
Kinda the setup I am looking at also in my 2021 SX195.
Looking at swapping my stock speakers to the Wet Sounds and running a free air 10” or 12” in the port side helm.
looking at the HTX 6 channel amp with 5 and 6 bridged to run the sub and the other 4 channels to my 6.5 speakers. With the Wet Sounds MC-20 head unit.
I installed a 10” IB sun and dedicated amp under the throttle arms on my boat and think is sounds fine. Recommend that wherever you install the sib that you get a dedicated gain switch for it. When the bass hits too hard I’m my boat and vibrates my legs to the point I’m wondering if ive got engine problems the gain switch pays for itself in peace of mind/no down time figuring out where the vibration is coming from or how to reduce / fine tune it.
my few install tips. Drill a pilot hole in the location you choose and check the depth with an uncooked / un boiled spaghetti noodle. Also make sure the area you are going to drill into doesn’t have any wiring behind it. Yamaha tended to hang the wiring high in my boat.
kgower
Buford, GA
222SE
That's pretty much what I did. I highly recommend a set of mid cabin speakers.
evosteve
195S
I went with one sealed JL M6 10” and had my storage door fabricated by a great local car audio guy to vent. Looks and sounds great. Super clean and no rattling. FAB901DF-3EA0-4EAB-8EE6-81258349C1ED.jpeg
