    With a Maximum discount of 35% this is the sale to get in on!
Deck drains fsh 190
nyfan78
Palm Coast, FL
Have a 2016 fsh 190. I was hosing it out today and noticed the water pooling up. The drains were draining just slow enough to cause water to pool up on the deck. Any ideas?
SgtBFGunner
Florida's Gulf Coast
There are one way flapper valves in the house on the way out. I always kept a thing piece of hose around and would pole it down the drain and it would open up enough to let the water flow out faster.
The other issue is, some people's flappers were put in backwards. A forum search will find this topic and pics. The valve is directionally marked.
Dumbassbass
Western Basin Lake Erie
I have a 210 FSH, mine was also draining slow, I found the drain lines were installed with inconsistent fall. Hoses or lines were not always lower to the exit side.
Elliott
Savannah GA
Also, debris tends to lodge in the drains causing slow draining. One of the first things you should try is directing hose water down the drains to flush them out. You can seat your water hose in the drain (inside the boat), and then using a rag seal it to force the water through the drain.
If the water pours out, you will have: flushed the drain and confirmed the drain is functioning/installed properly. I flush my drains every few months, and they drain fairly well.
JASmith
Minnesota
That is a good idea, my boat has been plugged since I got it a couple weeks ago. I tried pushing air through it with a compressor, but no luck. I like the rag seal! Thanks.
brownjjst
Douglasville Ga
FSH Deluxe
Same thing happened to me a couple of weeks ago.... I took my air compressor and blew it out from the floor side, all of the trash came blowing out of the boat. It is easy to get these clogged up! add this to the to do list for the boat!
