MidnightRider
- Zumbro Falls, MN
- Malibu
- Wake
Happened across the Owners Manual for the factory installed depth finder transducer (was stuck in bag with the boat Manual). There is a section in the manual for transducer called "Winterizing". This instructs you to remove the transducer to drain any water trapped between the through-hull-sleeve and the transducer itself to prevent possible breaking/cracking if the water were to freeze in there. It actually says remove "blanking plug" but that is because it earlier on says to remove the transducer and insert the blanking plug whenever you remove the boat from the water (so the blanking plug would in theory be installed at the time of winterization). Removing and installing blanking plug every time you pull it out of the water seems very excessive to me, but the fact that it says to remove it to drain water that may be in the sleeve concerns me. There isn't any difference in the sealing/o-ring configuration between the blanking plug and the actual transducer, so if water egress is possible with the plug, it is just as possible with the actual transducer. Anyone else see this manual? Anyone do this water draining procedure when winterizing? My concern about removing it would be to weaken the seal more than just leaving it alone. Plus I haven't looked to see how accessible this transducer is as far as doing this procedure. If I remember right I think it is in the bilge area which would require to unscrew and break the seal on the bilge cover to get at it. Who thinks this is worth doing? Or should it just be left it alone?
