Blenderhead
- Spout Springs North Carolina
- Malibu
- Other
I tell you what @haknslash - those could fit nicely on the transom to the left and right of the jets and combined with a jet wash deflector potentially provide a ton of value... the only fear I would have would be the constant water pressure trying to separate that device from the boat leaving a gaping hole if it comes off. However if attached correctly as it is on a Moomba it might work awesome!! The Theory checks out at least...Yup that's how I imagined it would be if mounted on the side of the hull. I didn't anticipate my friends wedge was going to be effective so good to know you've tried it. You would need a big piece of material to sit way low in order for it to be in any decent amount of water but then I'd feel the suction cup would be under great stress and likely fail unless you added another I suction cup to sit beneath somewhere. I've seen the plastic ones snap at the handle.
I know when we list @Bill D 's boat with 2k+ lbs his swim platform is ankle deep on the surf side and the non surf side is a little higher out of the water than the boat would be without ballast. This is why I think the only hope we have for any effect on a jet boat is getting it as close to he transom and below as possible so that the top of the surf wedge is just at the non surf listed water line.
If I was brave I would just try retrofitting the Moomba Flow gates as they look perfect for our boats but the small surface area compared to other surf devices baffles me he a little. I love the simplistic design. Pull a spring loaded pin, set the desired amount you want and off you go.
