@pete4180 The best comparison of CARB vs non-CARB that I know off is reported by
@Mainah here:
https://jetboaters.net/threads/carb-vs-non-carb-side-by-side-test.10521/
He reported the difference of only 50-100RPM, with the CARB engines topping out under 7500 RPM at WOT. Unfortunately, I am pretty sure those numbers will be less forgiving for a single. I think ribbon delete may actually do (some) magic.
I don't know of anyone reporting the ribbon delete results specifically for the CARB 1.8l engine, but I would definitely do it -- it is a no-brainer and it can not hurt:
I have done it in 3 separate 1.8 N/A engines (one in a 190 and two in a 240) with very reproducible results - a gain of about 200RPM on top. Or a gain of less than 200 if hitting the rev limiter at 7800+, but that is not going to be your issue, at least not right now. None of mine 1.8s were CARB, but I bet you you will see at least some improvement with better air flow, albeit may not be as dramatic as in a non-CARB.
It is a completely reversible mod -- can be undone just as quickly. You could start by buying nothing, just remove the ribbon (and air filter, too) and see how she runs. I may post a quick report on how I did mine this time, but there is already plenty of info around that topic, so no worries. Let me know if you need any pics or help.
