Damsroy
- LI Sound
So my 2016 AR240 has been wet splipping in Long Island Sound for the entire summer.
I will document year after year the effects of salt water on the boat and the maintenance needed (steering cables, pump housing, etc) along the way.
Boat was purchased before the start of the season in 2019 with 86 hours of fresh water use. Always trailered and stored inside during winter months. Boat has now 135 hours. No issue whatsoever to report this year.
Engines are flushed with Salt Away (I installed TOW valves) after each outing and boat is rinsed the same way. Boat is always covered with deluxe mooring cover.
You can look at the jet pumps below as well as the rudder. Not as pristine (....) as if used in fresh water but not too bad imo.
Boat hull, interior and hardware still look like new.
I don't like bottom paint and you can see the waterline but not having bottom paint was not an option.
Zinc anodes were pretty much 25/30% eaten and had to be replaced after a year.
Engine compartment is still pristine.
I know I might have to replace steering and reverse cables after two or three seasons but so far no issue.
All in all a great season and looking forward to next year!
