Damsroy
- LI Sound
So it is time for this year update....
this year is the third season wet slipping in salt water.
Boat still looks like new and runs like a charm..however this year there was a little more work and money to bring the boat to top notch condition.
Besides the typical oil change, bearing greasing and new spark plugs i had to do the following:
- replace the jet pump reverse control cables. The thread at the end that connects to the spring clips was totally corroded. i also added the new wire that is connecting the anodes to the end of the control cables
- replace the rudder assembly. my steering was really stiff and reading all the threads here I purchased a new steering cable assembly. After further investingwtions the steering cables are totally fine. The rudder was totally seized. New rudder and $350 later and everything is back to being as smooth as butter. I have a brand new steering cable assembly seating in my garage for When it is time for replacement. End of this seaon? Who knows?
- removed the pumps, check the cones, sanded the pumps, etching primer and Trilux paint on the pumps. This is annual maintenance for me at this stage
- sanded bottom paint and added a new coat of bottomkote.
- treated entire hull with Rejects, all interior with 303 fabric guard And Bimini and mooring cover with 303.
This is it! Not looks and run great! 156h on each engine at beginning of the season And ready for some fun!!!
Bottom line:
- people telling you that wet slipping in salt water won't do anything to your boat are lying...There is additional care and cost associated with wet slipping in salt water.
- people telling you that those boats are not designed to be slipped in salt water have no idea what they are taking about.
There is clearly additional care and maintenance when you slip in salt water but it all worth it and boat still looks and runs great!
Bottom line:
