Drilling rivets out of fiberglass
Mfpaul
SeaDoo
So I need to replace a bilge blower motor in. 2007 Utopia SE. It’s naturally in the engine compartment, in a not so convenient spot up high. I understand I would drill the Rivet heads off and the bracket and motor should fall free. But isn’t part of the Rivet then still embedded in the fiberglass. They don’t go thru and thru so I can’t push that part out the other side. Not sure how I get the rest out. Once/if I do, can I put a new Rivet into that same cavity/hole to remount the bracket? I am using an exact replacement blower assembly. Lastly, I have two blowers. Is the other one likely not far behind to fail?
Just drill the rivet head and when you replace the part then move the rivet hole a little bit away from the original one say 3/4 of an inch just in case they have some extra material there for the rivets to grab on to.
Thanks. Make sense. Any idea how deep I need to drill the pilot hole for the new rivet?
Probably no more than the depth of the rivet.
