Ronnie
- SF Bay Area
- Limited S
I have my wiring set up like @Kahuna Khris but with two additional leads for the second motor. I like the way @Bubblehead suggested because it would clean up the wiring a little but I would have to use some type of extension to get all of the accessory leads to the switch since there is not a lot of room on the respective terminal which is on the bottom of the switch.
Now I’m interested in what others think/are doing. My plan is still to just replace the start/house battery with a deep cycle battery. I will probably go bigger and purchase it from Costco for under $100, interstate brand but not agm. Here are two standard sized ones I was looking at last night but I need to verify the specs on what I have before I buy a new battery.
