bronze_10
- Raleigh / Wake Forest Area..
- SX
Three letters... Ecu!
Have you checked your oil level yet ? is it overfilled or smell like gas ?That’s something I’ve never looked at. Thoughts on tests for that? The injector that stays open for me is cylinder #3.
HALLONew 2007 AR230 owner, this forum has a been an amazing resource and wanted to ask a few question to see what others thought of an issue I possibly may be having. So I recently changed the plugs and oil, the oil was a little over filled in both engines but was not in the air filter. I did notice a smell of gas from the oil which I know is not normal. I haven't had any issues and have been monitoring the oil level the past week and haven't noticed any significant changes, but there is a faint smell of gas in the new oil. A few questions.
1. Is it normal to have some gas go into the oil from running at idle? Or possibly from rings (engine has 250hrs)
2. What are the chances I would be having the same issue on both engines at the same time (gas smell is in both oil)
3. I ordered Yamaha ring free additive to run through and see if it helps at all and other additives I should try?
4. Should I be looking for any symptoms of a bad ECU or bad injector?
The engines have been running fine 10k rpms and about 50 mph. Being new to the boat I don't know if it has been using any additional gas. Any help or ideas is appreciated.
HALLOYeah, this is already a new ECU. Put it in last year. Ran great for a while and now it’s back. I have the old ecu that was repaired by carmo and I want to put that back in because I opted for the heavy duty injector outputs but I’m hesitant to put that in if the problem will come back and ruin that one too. My injectors all tested fine. It’s just weird that holding down the switch on the trim tab would make it run smooth again. Also, new plugs will help for about two weekends then back to the same issue. I’m grasping at straws now.
