biffdotorg
- Pelican Rapids, MN
- Limited S
Ok, so I am noticing a trend on here that guys are replacing spark plugs annually on current 4-stroke EFI engines. Spark plugs are not overly expensive, but I am one to question the norm if I don't see immediate benefit.
A bit of background, I come from a bit of a motorsport, toy collecting background, so my experience comes from that of many brands and not just this one boat.
In the past, 2-stroke snowmobiles required us to carry a second set of new plugs, pre-gapped, as they could foul at any time. And you had to be prepared to swap them trail side. You knew when a plug fouled, as it would run rough, or rough start etc. To this day, carbed Yamaha sleds and Waverunners would require at least annual replacement as they would foul usually after the first couple tanks of gas as we ran out the fuel stabilizer.
So after 2 Carbed 2-stroke Yamaha snowmobiles and 3-carbed Yamaha Waverunners, I am 100% EFI 2-stroke Waverunners, and EFI 4-stroke sleds. And the annual swap of spark plugs is not as prevalent. Meaning, I swapped them on our GP 1300r's, but the difference was just a bit noticeable. EFI just really does keep the engine from fouling those plugs unlike before.
My four stroke sleds are still running the factory plugs! And this includes 5 different sleds with over 30,000 miles total!!
My previous 2-stroke EFI boat ran the factory plugs for around 100hrs until I swapped them as I had noticed one finally fouled. And that engine ran like a top all the way up until that time.
My motorcycle uses iridium tipped plugs like my truck, and it has over 33,000 miles on it, and it may just be coming up on the interval to swap them.
So that long story comes to the current boat. Twin 1.8ltr EFI four strokes. The manual lists checking the plugs for fouling and gap, but not replacement. But the need to replace these plugs is just not there, let alone annually. Can anyone on here truly tell me they noticed a degradation in performance by not changing them annually? And better yet, did you notice any performance gain by replacing them?
I have a full set sitting on my bench, pre-gapped. But I see no real reason to put them in. Maybe next summer after I work the stabilizer out of the tank of gas. But these engines just don't fry plugs like the old ones.
Opinions welcome. And if someone comes back with, "its cheap insurance" I will pre-comment with, "that is a fool spending money on insurance for a plug failing, that is far from catastrophic failure"
Thanks everyone
Thanks everyone
