electronic throttle
Shady
Dayton, TN
What year did the 240 start using the electronic throttle? Reading online i have saw various years reported. I also searched on here and didnt see.
J-RAD
Orem Utah
So, I'm no authority on this topic but I had a clue on where to look. Hydrophase makes the Ridesteady system for all Yamaha jet boat models equip with a accelerator position sensor (APS). On non E-series models, this sensor converts the position of the mechanical throttle at the helm into the electronic signal the ECU manages. I'm not sure how it's all controlled on the E-series models. From Hydrophase's website it lists the compatible model years for the 240 & 242 as being 2010-current. So that should be your answer.
Mechanical or Yamaha Jet Boat Throttle? | HYDROPHASE LLC
Beachbummer
Houston TX
If you mean electronic throttle control at the engine, where the throttle is controlled by APS, the answer above is correct. These boats may still have a control/analog/physical cable to control the signal from the helm.
If you mean electronic throttle controls at the helm / drive by wire, the answer is different. Only certain high end models have that.
Can you clarify what you mean by electronic throttle?
swatski
North Caldwell, NJ
2015+ all 242 E-series and 242X.
zipper
Boston Whaler
In 2010 Yamaha started using 1.8L engines with a TPS/APS. Prior years using 1.1L MR-1's have no TPS and throttle cable from the helm connects directly to the throttle body, with no electronic interface. If you mean E-series, electronic controls than @swatski has the answer.
Shady
Dayton, TN
I was referring ot the fly by wire. Sorry i wasnt clear enough, i was unaware of the differences which I think I s why I couldn’t find my answer. I see it was answered thanks all
