Engine whistling noise
Brad K
Yamaha 230sx Ho. Engines make whistling noise low mid RPM’s
Have you found the source of the air leak..........a whistling sound usually indicates air leak/movement. I would start at the air box/filter and the rubber hoses that attach to the Throttle body and intake manifold.
