Beachbummer
- Houston TX
- SX
What a pain!
This is by design. The hatch interlock switch is a 4 pole 2 way switch. When in the closed position the switch completes the loop on one od the wires needed to start the engines preventing them from cranking when the hatch is open. When in the open postion those wires are disconnected and the ingition is connected to ground killing the engines. One of the better engineered saftey features on a yammie. Of course when the switch height is not adjusted properly or becomes out of adjustment it can lead to a lot of head scratching. All of the analog stuff they got right over the years certainly helped them to become a market leader. Their first foray into human interface digital controls (connext 1.0) was a slap on top job that they hopefully learned from. Time will tell with connext 2.0 if that is the case.Just so everyone is aware, the switches in the wet locker have two settings, if it is pushed in just far enough, the engines will turn over but the ignition will not fire. I found this out last year when I had someone else put a rope away in the wet locker and the boat would turn over but not start, then when some friends were trying to help me diagnose it were standing on the wet locker door and compressed the switched enough to fire it up... and as soon as they got back on their boat, the boat cut off due to no spark.....
thanks PaulyB, That's the first time I've ever heard anyone mention that, I'm going to try it next time out by manually pushing down on the switches,Just so everyone is aware, the switches in the wet locker have two settings, if it is pushed in just far enough, the engines will turn over but the ignition will not fire. I found this out last year when I had someone else put a rope away in the wet locker and the boat would turn over but not start, then when some friends were trying to help me diagnose it were standing on the wet locker door and compressed the switched enough to fire it up... and as soon as they got back on their boat, the boat cut off due to no spark.....
