- Florida
- Other
- Other
Although I don't list these on my web page , years ago I made ezlocks adapted for people who were disillusioned with trying to install and remove the pin fix from their clean out plugs.
This option is still available upon request .
They are adapted for the larger holes used for the pin fix, you only use one on each plug and they operate exactly the same as the regular ezlocks.
Place them on the plug prior to installing it, push down on the T handle and the lock closes when the plug dogs are engaged.
To remove it you simply squeeze the ezlock to take it off, then push the release button to pull the plug out.
This eliminates trying to install or remove a pin while the plug is down in the clean out opening.
You would need to email me directly to order these.
I will custom make them for you when ordered and charge you the same as the regular ezlocks. I am mentioning this due to a recent email from someone who had the misfortune of installing some pins before realizing just how difficult they were to use.
