- Royal, AR
- SX
I am installing a new and different transducer. At most I will be able to use one of the three factory holes. The factory holes were probably drilled to 3/16th then a #12 or #10 screw was used to mount the transducer.
Some options that I have considered are;
Here is a picture of the holes filled with Life Caulk. I will reuse the fourth hole that is higher so it is not an issue.
- Fill the holes with Life Caulk and allow to cure. Add an additional blob from the inside. I filled from the outside today shooting quite a bit through the holes.
- Get some flat headed #12 screws, countersink the holes slightly, and install them into the holes with Life Caulk.
- Drill the holes out larger and fill with an epoxy plug. Drilling would remove all the old caulk and clean up some of the gelcoat damage.
- Order some quick cure 5200 and fill the holes. I have slow cure 5200 but I want to use the boat this coming weekend.
