Finally got my VHF radio, GPS and antenna installed.
kthrash
Madison, MS
Thanks to great weather yesterday I finally completed my install of the Lowrance Elite 5 HDI, Lowrance link 5 VHF and Pacific Aerials VHF antenna.
what type of wire did you use for the vhf antenna? How did you pass it through the hull?
I bought a pacific aerials pro 1" rail mount that included the cable, I disassembled to mount to the clamp I bought from bullet lines. I then drilled a hole in the tower ran it down to the bottom of the tower and drilled a hole through the hull. You can see it in the pics above.
I have another post somewhere showing the antenna setup off the boat
Looks great!
