tdonoughue
- The Woodlands, TX 77381
Finally found a free night, took the kid up and we installed the #KeelGuard. Woot!
Very easy install. Most difficult part was dealing with the length of the unwieldy thing. But the fact that the center had a separate protector strip from the sides made the install a breeze. I was going to use masking tape to tape off the outline, but we had some 'old tape' issues. So I abandoned that idea and used a dry erase marker to outline where it was going to go. Now, that did scrape off some as I scuffed it up with the sanding block. And what didn't come off there came off with the primer. But I still had the 'start' spot I had marked, so it all worked fine.
I will edit this in a sec and add pics. 'Cause I know. It didn't happen without pics.
