Fire extinguishers in 212x
jayman1234
Toronto Canada
255XD
Looking for suggestions on the best location and method for mounting our fire extinguishers.
Have one in the helm compartment and one in the storage where the batteries are.
I have 3 fire extinguishers, because 2 are required. I have a dry chemical mounted to the inside wall by the batteries (I unscrewed the bracket for the table, added the bracket, and screwed the bracket back in). I have a dry chemical mounted in the helm compartment (high up, right by the door on the aft side of the hatch). I have a CO2 mounted below that with the bracket situated so that the extinguisher just sits on the bottom of the compartment (those are heavy suckers)--then I have a twist-tie-type cord holder also holding it back to the wall. Sits right below the dry chem one.
(BTW, after researching, I discovered that probably the CO2 would be the best choice for an engine fire. A dry chem would kill all the electronics with corrosion, but probably would not kill the fire, as the spray through the fire port would go right between the engines--not where a fire is likely. CO2 would not kill electronics, is a gas so would smother everywhere and basically flood the whole compartment very quickly.)
What is the criteria for two being required?
I sit corrected. One is required for less than 26'. 46 CFR 25.
(I still have 3)
