- Norman, OK
- SX
@Bruce - The 13lb Mantus will not fit in the anchor locker as is. HOWEVER, if you were to remove the round bar, it will fit if you were to raise the plastic block holders an inch or so. I plan on doing this. The round bar is held in place by two bolts. My plan is to find some type of quick release bolt that I could easily put on and remove.
Anyone have any good suggestions or tips to replace normal bolts with some sort of quick release item?
@DCB-270 - You will love the Mantus. I am sure the 8lb will hold just fine. When we throw the 13lb it has caught immediately. So much so, it has came close to ripping the anchor line out of Amanda's hand. You are in for a treat my friend with your new anchor.
