- Rosebud, Mo
- 242X E-Series
Finally I am taking the steps to make the 242X perfect for me. Like everyone knows putting 3 high volume pumps in line with one intake is a major flaw. Even the 212x has 2 thru hulls for its ballast system. Any ways here is what I am doing I have ordered 2 more thru hull fittings and I am going to install them on the flat right above the articulating keel. I am going to use one for just the port ballast bag pump and the other for my transom bag fill pump. I have most everything on order and I will post pictures as I progress.
So far tonight we have taken the port bag factory hose off and the flow rite fitting out. I will then plug it with an NPT fitting.
I have also mounted my transom bag pump and drilled and mounted my quick connect hose port.
Last I have made up my quick connect hose for the transom bag.
More pics to come as parts come in.....
