- Daytona Beach Florida
- SX
I have not had any overheating, the first time this happened it corroded away a piece in the manifold and water somehow got in oil, this time I have had a small water leak into boat which I decided to address so I pulled that engine and sure enough manifold was corroded to a point that any day was going to be an issue. Soni decide to pull manifold off other engine, sure enough center section has a corrosion spot that requires it to be changed.@fairpilot I have been running engines for 60 flashes In No-Wake mode, without supplying water. I have not had any overheat warnings while doing this and the engines get warmed up, hopefully drying out cooling system.
Like you, I always flushed for up to ten minutes after being on the water and still had overheating.
Last March after pulling both engines and cleaning the cylinder water jackets and oil cooler water jackets, I went on the water to test. No overheating. I flushed the engines as always and thought the overheating problem was resolved. But, afterward, while having the boat layed up, I periodically started engines and ran on hose for up to ten minutes each. That is where the problems began. I started getting overheating on engines that had only been in the water for a few a hours. I pulled both engines, again and found the cylinder water jackets and oil cooler water jackets packed with that jelly like substance you mentioned. Now, I am preparing to water test again.
Regarding tie valves: I do not think pressuring the cooling system to attempt better flushing is wise. There is barely a quarter inch space between water passage ways and cylinders. Water/steam could be forced into cylinders.
Also the first elbow in in exhaust ( first big rubbber boot) is really corroded up. So I fixed that. As for the jelly substance, I really only find that in thermostat housings, I take them apart about every 6 months and the have it in them. The water jackets at manifold were mostly dried crusty salt and maybe what looks like some sand.
My problem now is I'm having a hard time finding a decent used inner manifold, a new set of manifolds is $870. If you know of a used center manifold from a FX 140 let me know. And thank you for all the information
