Flushing while on boat lift
Dthiss
195 Open ID
I have a 2018 195 Open with a 250 HO and had an opportunity to rent a boat lift on the intercostal for a very reasonable price and took it. The only issue I have is when the boat is on the lift I can’t reach the fitting to connect a hose to for flushing. Does anyone know if this fitting can be used at all to flush the system after use? Or what it‘s for?
ALAN MANN SR.
Wimauma, Florida
HO Impulse
It looks like a flush port that someone lost the cap and rigged a replacement. If you look in the engine compartment to see where it goes or if you unscrew it and a garden hose screws in there, it will be the external flush port. I don't have a 195 Open but I had an external flush port installed on my 165. The hose from that fitting will tee into the flush port underneath.
Dthiss
195 Open ID
So I’ve found pictures of this port with a sticker saying “Exhaust Flush, see owners manual.....”. So now I have another question. If this is the exhaust flush and it’s tied to the inter cooler flush then why use the one under the transom? This one obviously is easier to get to so I don’t get it.
Dean P
Saint Petersburg, FL. 33702
Chaparral
VRX
Exactly, you do not have to use the one under the transom. You can actually plug that one. I used a plug I can turn by hand should I ever need it.
ALAN MANN SR.
Wimauma, Florida
HO Impulse
I was told when mine was installed that you DO NOT plug the one underneath. yon leave that one alone.
Dthiss
195 Open ID
Seems to me that the one below should be plugged. Water taking the path of least resistance and all.
ALAN MANN SR.
Wimauma, Florida
HO Impulse
Do what ever you want, but I have been using mine for three years now and with no problems. It still flushes the exhaust and intercooler just fine, because water comes out of exhaust just as much as before. I had mine installed to make it easier than hooking it up underneath. I just thought you might want to know how I have been using mine.
Dthiss
195 Open ID
Thanks for all the input Alan. After scouring the Rotax Manual I found the line down bellow called “Exhaust Water Return“. I’ll leave it open and see how it goes.
Dean P
Chaparral
VRX
Was told by the dealer and their mechanic to plug it. Honestly, I don't think it hurts either way but when flushing I noticed a lot of water exits from here where it should be exiting from the exhaust. So I plugged it with no issues. @ScarabMike might be able to comment with his thoughts.
ScarabMike
Scarab Forum Lead
Green Cove Springs, FL
HO Impulse
Ok folks, here is the deal with the twin ports.
One is the exhaust side, the other is to flush the intercooler.
You need to flush the engine through the normal entrance in the jet pump area. It will flush water through the exhaust, and it will also come out of the second flush port. You do this no more than 60 seconds. Then you put the hose on the second port, and run the engine again. No more than 60 seconds again. You will see water coming out of the first flush port. Do not block any of the ports when flushing. The water flow helps clear out debris from the exhaust and intercooler.
ScarabMike
Scarab Forum Lead
HO Impulse
Here is a PDF on flushing the supercharged 1603 rotax engine. The LH and RH represent each port of your Scarab,
Dean P
Chaparral
VRX
Hi Mike! I do not have twin ports for flushing with my 1503 250hp rotax engines. Albeit I have a Chap but would assume it the same on a scarab(?). I only have the one hook up to flush each engine. I installed a 2nd flush port so I would not have to hang over the swim platform to screw in the garden hose. Should I block off the original port (the one I cannot reach) or leave it open as water flow thru this when flushing from my new port?
ScarabMike
Scarab Forum Lead
HO Impulse
The two port system is for the new ACE engine. You have the old 1503 with one flush port. Im not sure how you added a second one, but because the 1503 is plumbed differently, I would make sure the exhaust, and intercooler are being flushed.
