Freaking out!!
Glassyo182
Hi guys I hope you are all doing well!
I was flushing the motor of my Yamaha AR190 after a day of usage today, and I was using a hose that had less pressure than what I usually use, I connected it and started the process and notice that the water wasn't coming out of the cooling drain like it usually does (dumb me), I kept going for like a minute and I got the overheating signal (visually and the sound). I stopped the process and waited for a couple minutes before I started again with some more pressure (it started coming out of the port like it usually does).
I really hope I didn't mess anything up, this is the first time that this happens to me!
Anyone had the same problem in the past?
Regards
Cobra Jet Steering LLC
Vendor
Florida
You are fine, don't worry, it happens and you caught it in time this is why you always monitor the flushing process so you can react instantly.
BigAbe75
Litchfield, IL
Don't know and I'm not an engine guy, but from what I've read here... I think you're probably fine if you got it stopped when the alarm sounded. Especially, since you got it started back up afterward. I think the concern would have been if you stopped the engine before you cut the water and ran water in the engine. Again, from what I've read here... check the oil. If it's a funny color, change it sooner rather than later.
If @Cobra Jet Steering LLC 's first reaction is that you're ok... that would be good enough for me, as well. :)
Seadeals
Greenville, South Carolina
You are fine. The engine ECM protects it from an overheat and the alarm worked as intended. No biggie, just don’t make a habit of it.
Vendor
Florida
He won't have any water in his oil it takes a while for that to happen even if he did shut off the engine first plus he had insufficient water pressure so the water is no worry.
I have had weeds overheat an engine and set off the alarm numerous times.
One thing to remember about the alarm and limp mode,if you are ever out in the boat and the alarm goes off and your engine goes to limp mode.
Never think it is a safe mode!
If you continue to run the engine you will damage it so shut it off and find the problem.
The last time I had that happen my oil filter split and my engine had no oil. I stopped and flagged down a boater who towed me back in.
The engine did not have any problems because I did not continue to run it.
https://jetboaters.net/threads/new-oil-filter-failed-just-did-the-oil-change-2-weeks-ago.18678/#post-321338
Glassyo182
This is all very helpful! Thanks a lot for sharing your experiences!
Regards
