Matt Wetzel
- FSH Deluxe
Got s a replacement windscreen for my 2017 FSH Deluxe. The port side of the windscreen doesn’t seem to have enough bend in the angle between the front and the port side windscreen. The result is that the windscreen latch housing has been pulled out of the console by the tension of the incomplete angle. I would expect that the angle between the front and sides to be 90 degrees but for the port side it is more than 90 hence the tension.
Obviously i can reattach the Housing to the console but I was wondering if there was a way to give it a little more bend in the windscreen so there is not so much tension on the latch.
thanks all
Matt
thanks all
Matt
