Fuel Hatch Removal
Chillypilot
Barrie, Ontario Canada
I've noticed a lot of people have had trouble removing their fuel hatch, so I was a little nervous about removing mine. I think many people try to do this job with the wrong tools and strip or break the screws. Glad to report mine came out with no problems. Here's what I did/used.
1. Sprayed screws with penetrating oil several times. I let the oil sit for 2 days.
2. Used a impact wrench with 3/16 square male pipe plug socket. ***caution*** impact wrenches create a lot of torque. I would not use it to tighten the screws on the hatch. You could drive the screw through the hatch!
3. Drank some coffee with baileys. Still freezing up here:(
Pretty dirty under the hatch. Looks like I will have to replace the seal.
Also removed my plastic scupper today. I believe it was good but it did crack quite easily during removal. I'm replacing it with a stainless steel one.
Volffas
Alexandria, KY
I'm glad to hear it came off ok. Can I ask why you removed the fuel hatch?
Chillypilot
I'm doing some sound proofing. I'm placing some roadkill stinger similar to dynamat on the underside.
Volffas
Alexandria, KY
That would make sense then. Let us know how it turns out! Hopefully warmer weather is on it's way for all of us.
graham cormack
hi, just wondering where you got the impact bit in pic 2 from? ive been trying to source one but cant get one anywhere in the uk!?,?,
thanks
Murf'n'surf
Naples Florida
thanks
I just saw some on eBay. Maybe they ship over the pond?
Chillypilot
graham cormack
hi guys i setup an account and ordered some from lawsons last night and i got an email back saying they dont do overseas, so right now im away to head uo to inverness where there is a decent hardware store who says he might have!!
@graham cormack did you find one yet ? if not start a conversation with me (private message) with your contact info and we will work it out,
graham cormack
hi Scottintexas yes I got off ebay in the US it just arrived last week so havnt had a chance to tackle the bolts yet, I managed to get my steering cable freed of a bit, so I think I will leave this till the winter and tackle it then!!
thanks for offering to get the impact bits for me though, was much appreciated :)
AZDANSX230HO
Passed Away
In Memoriam-RIP
Prescott Valley, AZ
View attachment 4935View attachment 4936View attachment 4940
You got lucky getting them all out, I had one bolt so stuck in there I had to drill the head off the bolt, that was after penetrating oil, etc. Tried to use some vice grips to remove the bolt once the hatch was off and I got about 1/4 turn out of it and would not come out.
bronze_10
Raleigh / Wake Forest Area..
I read the horror stories and debated on weather i would ever try to pull up my fuel hatch... decided i was gonna man up and make it happen.
Most bolts came out easy.... some even seemed loose but they weren't. One gave me a moment of pause.. it came up about one turn then locked down... after all the others were out i decided i was just gonna put the power to it with my impact gun and poof.. out it came... it wobbled though so i dont think it was straight.
An idea what these blocks are for? Looks like what they used to hold the tank in.. maybe extras?
Murf'n'surf
Naples Florida
Those are pads to isolate the metal tank strap and the poly tank. Usually they are at the top and bottom edges of the tank.
buckbuck
Texas
@bronze_10 After cleaning the channels I suggest you consider waxing them to help with future cleaning. Also check your deck drain fitting. I had to silicone mine as it was leaking.
bronze_10
Rgr... i pulled it up... took pics and set the cover back down... the wife is out of town.. ill wait for her to return to clean it.. lol
Speedling
Cedar Lake, IN
SS
Yup they are just extras from wedging in the tank.
Speedling
Cedar Lake, IN
SS
Glad you had it easy! I found mine had corroded to the point my fiberglass was screwed up. Now i am drilling the screws out, over drilling to clear it all out, and epoxying new nuts in before putting my hatch back on top, which still needs a little tlc with the giberglass on the backside.
Count your blessings!
bronze_10
Oh i am... i was fully prepaired for the normal nightmare...
