Fusion 200I wired remote issue
bronze_10
Raleigh / Wake Forest Area..
For those skilled at stereo instalation and specifically the fusion system I could use some help... I installed a fusion ms-ud750 with speakers and led speaker rings and all that stuff... the radio and the speakers sound amazing.. I also installed a wired fusion 200I swing deck remote. With the nema 2000 cable that came with it. The stereo has a setting to power the remote unit in... when I click that the remote will turn on but it says waiting for network.. check connections. If the connections were wrong it would not power up. I have also done the update on both the radio and remote... anyone have any advice or experience with fusion that would she'd some light on this? If so... text me and let me know due to working on the boat with the new radio on... !!!!!! 919 278 8693
Do you have to use setting in your head unit to address the remote? Or turn on a "remote for nema"
The only option it gives me is set ip address as dhcp or static.. as static everything is all 0
Are you sure that model remote is compatable with that model head unit?
Hi same setup as you I think; can you share what cable you bought? Was it dedicated nema power?
Actually when I clicked thru nrx power I was able to use remote with no other config. I put inline terminator at the transom remote and terminated with the tee at the back of the head unit.
I bought a cable bu i didn't need it... there is a line block that came with the remote that I forgot to install at the remote...
Thanks I had a slight panic moment there... I have an extra 6m cable that I don't think I need either.
