Garmin transducer cv23m-tm
I know You know
South Florida
Does anynone know if this transducer can be installed inside the hull, I do not need water temp and I know installing a transducer on the transom of the 210 FSH is pretty tough.
If you want accurate reading of structure or sonar hits (fish), do not install in hull. Get a thru-hull ducer...they are not expensive, relatively.
