Livewire
- Troy, AL
- Limited
Finally got around to attempting to repair the damage from previous owners beaching. I scuffed it up with some 220 grit sandpaper. Then cleaned it with alcohol. It was hard to keep enough spectrum paste on the keel edge. I used a plastic body filler spreader to even out the paste, but if I tried to smooth it out the fiberglass spots would show through. So I wound up just mounding it up on the edge. Going to have to sand gingerly as to not to remove too much there.
I’ll start the sanding process tomorrow after I get home from work.
