Give Me Shelter
JetBoat195G
Massachusetts
Scarab
195 G
I really envy you guys that mention putting your boat in a garage, or worse yet, showing pictures. My garage is about two inches too narrow to fit my boat and trailer. I studied and pondered for a while how I could modify the garage opening to fit the boat and trailer, but in the end, I decided that reframing the garage, and evicting my tow vehicle from the garage, to fit the boat and trailer was a bit extreme.
I didn’t like the idea of having to take off a tarp every time I used the boat or wanted to get into the boat, so I bought a shelter. It's been about four years now that I’ve been using the shelter, so I thought that I’d share my thoughts (a bit of a review) in case anyone else can benefit from my experience. Below are some images of my Scarab 195G in the shelter to give you a sense of how it fits. I’ve been fairly happy with the way that the shelter has held up. I did spring for the middle of the road heavy duty PVC cover. It’s a ShelterCoat Custom Round Shelter, 13 ft. wide x 20 ft. long x 10 ft. tall Heavy Duty PVC 14.5 oz. Green in case that helps anyone with the dimensions. One issue that I’ve had is condensation within the shelter, but that may be because I merely set it up on my yard without putting down stone, concrete, etc, since I expect to move in a few years and wanted to be able to remove it with minimal effort. I did buy the vents that you see at the top of the entrance, but they don’t provide sufficient ventilation to prevent mold/mildew from developing on the interior of the fabric over time, requiring some cleaning every once in a while. I do pull the snow off of the shelter with a long brush when we get a New England snowstorm. Again, just some thoughts and dimensions in case they are of value to anyone.
Dixemon
Low Country Ga.
That looks good, I built something similar to that with electrical PVC and 16 mil tarp. It is solid as a rock. That is way nicer than what i have. But i tell you, not having to tarp it and keeping your boat protected from sun and leaves is worth a million bucks.
Beachbummer
Houston TX
You could put a fan and dehumidifier in there to help with the mold. I bought a small one for 40 bucks from Amazon and it connects about a quart a week. It helps with the mold quite a bit.
Scarab16
Scarab
195 G
I use a similar shelter for my 195. its a 12x20 and fits perfectly. I use a roof rake to keep the snow off it in the winter.
TimW451
@JetBoat195G In regard to ventilation, if there Is only the top vents on the ends, you will only get good ventilation when a breeze pushes on an end. If you have a vent or gap at the bottom you can get a convection current. I would look at adding a solar powered fan to at least one of the current vents, one on each would be better (one pushes, the other pulls.) HTH
HangOutdoors
Royal Oak, MI
Where did you purchase this from?
HangOutdoors
Royal Oak, MI
I think if it was 12' tall I wouldn't have to put down my tower to get it in there. Also would need 24' long. It got pricey quick. Not sure I could have one in the back yard per the city, but definately worth a questions or two.
