SB78
- SX
I have a 2019 Yamaha SX190 and I'm looking to do an in-hull transducer install. The units I am most interested in only have transom mount transducers that can be glassed in, so the issue is finding a flat spot to install them (because they don't adjust to the angle). My problem is that there is no flat spot available. The only feasible location for a transducer install rests on an angle of around 18 degrees. Before giving up and settling for a unit with the adjustable in-hull transducer, I wanted to run an idea by this group. My thought was using epoxy to build a flat base (as thin as possible - just enough to bring the angle up), let it harden up and then glass-in the transducer on top of the epoxy base. Is this a stupid idea or would it work?
