B0at1n
- Little elm
So I purchased the GO5 because I really wanted something flush mounted that looked almost factory.
The delima. It barely fits in the spot and I am concerned with being able to make the cuts and how thin it will be around the edges, if i can even really cut that close without it snapping or breaking.
So the question is should I install this or look for another option.
Here is it in the front.
Here is the back
I am going to either have to remove the epoxy that holds the mounting screw and move it, or maybe just leave it off. Other option would be to just have 3 screws on the G05
I trimmed the template so the corners are where the mounting screws go and the shaded area will be the cut that the unit sits in.
Here is the boat with the dash off. The lip behind that the dash piece Mounts too will require a little trimming but shouldnt be much.
Stock photo for reference.
Any advice would be great!
Anyone In the DFW area that wants to come help is welcome as well.
Here is the back
