Wrecked Rooster
- Ada, Oklahoma
Speakers came in. 8” kickers replacing the factory 6” speakers. Looks like it’s going to be a tight fit (circumference) for the grills. Depth I’m good to go. The factory wire is 16 ga. Which according to the attached chart should be fine. Pulling ~12.5 amps at 150 watts RMS according to the manufacturer. Would have to put an amperes reader on there to confirm actual draw.
Not going to lie, cutting the hole is going to be scary. Especially with the tight tolerances. I’ve never installed an audio system but am pretty familiar with wiring. Also, I think I’m digging the charcoal grilles over the white. Matches the charcoal in the seats perfectly. Fingers crossed everything goes in smoothly.
