Greasing impeller bearing.
Marvin willis
Morehead city nc
Are yall filling the cone with grease when greasing the bearing? I just greased boat and jet ski and neither had grease in the cone.
Marvin willis
Morehead city nc
I figured people are putting grease fittings on the cone. So what's the difference?
GNX231
STUART FL
Limited
I think a grease fitting in the cone is a great idea. i redid thhe pump on my seadoo a few years back and i filled the entire pump with grease and then the con as well until it looked like an ice cream cone so the bearings are always in grease. no problems since.
justason
SWAG Forum Lead
What jetski? I was greasing recently And I couldnt find a fitting in my 110hp waverunner.
Dare i ask?.....cone?
Marvin willis
Morehead city nc
Yes I think they all have a cone on the end of your prop that you unscrew and grease the bearing. I know on my ultra250x people talk about the bearing going bad and when it does it breaks the crank on the motor Too
KXCam22
Kamloops BC
I modified mine with a drain plug and use gear oil. It is known mod in the PWC world. The grease needs to be API#0 which is quite thin grease that flows. Some use a mix of amsoil grease and amsoil gear oil to make a slurry to replace the API#0 grease. You can tell I researched it to death before I did the oil mod. Not sure that you can put a grease nipple on since the trapped air would get forced out the seals. cam.
aarons1k
Campton hills Illinois
My past Seadoo I had to grease the cone when I installed new wear ring , do yamaha use the same set up ?
Marvin willis
Morehead city nc
I just used reg marine grease. I thought about the oil mod but I like to take it apart and visually see that the bearing looks ok
Big Shasta
Panama City Beach, FL
