Greetings ar230 yamaha. Rob the newbie
robeswc
Hello all,
I have a HO ar230 2008 comissioned in 2010.
I have water going into my engine bay the level hit the height of the oil filters. The water is coming out of the male end of the red hose. I do not know where it is to be connected. I greatly appreciate any help or sugguestions! Thanks for your time in reading this thread!
Rob
On my 210 FSH, the coolant hose is red like your picture.
Does the water come out when the engine is not running?
Does it stop when the engine is off?
Did you get an over temp alarm?
Looks like someone rigged an engine flush connection, but the female hose bib is missing.
The red hose connects to the flush port on one end and the “y” on the other end from the water intake screen. There is a check valve that leaks and I had to replace the whole red hose assembly a while back.
Thanks very much, TeenGee, had a baby panic attack your response is greatly appreciated!
Rob
Zipper thank you, my son winterized the boat, hence the problems.. A for effort F for plan. lol
Hi, the water runs only when the port engine is running, stops when shut down, engine did not come on. Maybe because it has a nice cool bath. I had a hell of a wake when heading back to port.
Thanks again!
