Guages not working
danielcasey01
Port Republic, NJ
Hi Everyone--
I have a 2008 SX 230 which, generally, runs great. Got to boat yesterday and battery was completely drained. Switched out to my backup and engines fired up great. The problem is none of the guages are working (blower, lights, bilge, depth finder, gas guage). Checked the fuse that is closest to the positive battery terminal but that is fine. Thinking this is something simple but can't figure it out.
Any suggestions?
Thanks,
Dan
are you sure you connected all the wires at the battery, should have been at least 3, 1 for each engine and one for accs.
thee fuse you checked was mounted up near the wall in the battery area ( if it was a stock set up) ??
i checked and double checked the wires for the battery. Maybe I missed something. Yes, fuse i checked was mounted on the wall of the battery compartment.
