tdonoughue
- The Woodlands, TX 77381
Gotcha. Sounds like a bad relay. Do you have a meter?
I've got an extra relay I can send you, or you can buy a 5 pack from Amazon for like $12.
Ok. Yes, that is called a flyback diode. It prevents spikes when you turn off the switch (which should not be an issue in this application, I don't think). At any rate, if it is built in, that is fine. But it means that you need to have the polarity correct. Are you sure you switched them when you switched them?
Since my write-up, I have purchased an inflatable standup paddleboard that requires higher air pressure 15 psi. The AirHead AHP won't generate enough pressure so I bought a SUP pump and installed that.
I replaced the low-pressure tubing with water line hoses to handle the increased pressure. Instead of a modified Boston valve on the swim platform, now I have a standard water hose fitting.
The electrical stayed the same.
The benefit of this pump is that it has 2 stages. It starts out using a high volume blower like the AHP but at a certain pressure, it switches to a piston pump. This allows it to get 20+ psi.
The pump will shut off when a desired pressure has been reached. I had to hot-wire the "on" button of the pump for it to start as soon as power is applied. I still need to confirm if the auto shutoff still works.
I am still testing the installation. I'm hoping that the first stage inflator will still work well with tubes.
I will add to my original post if everything works out.
Seems like a leaf blower would be loud, large to store and consume lots of power.Has anyone ever tried using a leaf blower as an inflator by necking down the output to fit in an inflatable? The restriction from necking down may mean that no more effective but figure worth a shot.
Apparently no problem!Has anyone ever tried using a leaf blower as an inflator by necking down the output to fit in an inflatable? The restriction from necking down may mean that no more effective but figure worth a shot.
