LionShare
- Ottawa, ON Canada
- X
G'day all! It's going to be an electronics upgrade and install month. I've been busting my brain with trying to find the optimal spot to mount the Helix 7. After positioning it in every possible position around the helm, I've decided to go with the unit mounted above the tach/speedo area between the windshield and the dashboard.
With this in mind, I removed the speedo/tach board to see what was behind and how rigid the plastic is and it seems like it will be sufficient.
In the picture below, it's the upper dash black trim where I used paint to show where and what I'm attaching the RAM mount to. In order to not stress the plastic, the RAM mount base unit will be bolted (x4) to wood through the plastic and I believe this will be enough.
I searched this forum to see if this was done before, and if I looked with my eyes closed I do thank you for your patience. I also realize that most owners will mount their GPS/chartplotter/fishfinder in front of the throttles but this is where I plan to install my wetsounds LED controller.
In short, I'm looking for feedback regarding the chosen location's structural integrity for my application and if someone has done it before and if it stood up to the test of time. Everything in mind mind says hell yeah!
Let me know your thoughts and know that it'll be appreciated - CHEERS!!!
