Gym
- Falmouth, MA (Cape Cod)
- SX
@Alex Smith. You may want to do a "post mortum" Whereas you had a 30 amp fuse blow previously indicates, to me, an overload condition rather than a dead short. A dead short would not allow you to replace the fuse. It is still possible you have a transient short such as a skinned wire but I'm betting on an overload such as a large stero/amplifier system that may have been in use at the time of failure or it just may have been as simple as an overheat of the rectifier.
We're the rectifier cooling fins clean and free of dirt and oil? Check the condition of the other one. The rectifier integrated circuit is actually pretty small, composed of dides to change the AC sine wave to a flat DC sine wave for battery charging. The battery will filter out any DC ripple for a clean DC source for your radio or other DC devices.
All of what you see, when you look at a rectifier, are cooling fins for dissapating heat. If those fins are blocked or dirty the rectifier can overheat and cause trouble usually just causing them to burn out. Hopefully we'll all learn from this.
