the MfM
- Other
- Other
- Other
You'd only have fuel spitting out if it was flooded. So it's good that its not spraying fuel.
Put the new plugs and do your normal cold start routine.
If it doesnt run check and see if the plugs are wet or dry.
If dry you can put a little fuel in one or two cylinders and try again. I'd makeup a gallon of pre mix and use that. Starter fluid can wash the oil off the cylinder walls.... Small amounts may be ok but be careful putting too much down the hole.
