I opened up the front seat and checked all the cables they seemed to be plugged in tight, also checked the fuses in the back. Notice 2 female cables unplugged and one diag cable but everything looked good.
If blowers are on when you try to start does it drain the blowers output? Are all battery switches right? Undo the safety lanyard a few times and check the actual switches for the clean out. Could be a bad connection there or else try neutral a few times also.
I am clearly no expert but I would try the following: First if you have a volt tester and if you can get to the starter switch see if you are receiving power to them if you are it is possible the ignition switch is bad. I also know you said you checked the fuses and that they were good, however, I would double check them and then be sure that done are loose. If there is a starter relay fuse make sure it is not corrosive and or loose. You might want to wiggle it while your wife starts the engine.
One other thing you might check are the grounds on the battery etc.
Does the motor turn over? There are fuses in the back of the engine compartment. They should be in a black plastic box with a circular screw cover on it that covers the fuses.
As I go back over your post you have stated that the battery is charged and that your accessories work. Are they still working if not is it possible your battery is draining, however, unless it is totally dead you should get a little crank when you turn the key. Again I would recommend that if you can get your hands on a tester see if volts are going to your starter switch. If you are then you may have a bad starter switch. However before I would come to that conclusion I would recheck the fuses and be sure they are not corroded and are seated properly. I had this happen to me on my RV. I wiggled the fuse and was back in business. Not sure if you have a solonoid but if you do you have means to see if it is bad? I would also recheck your battery connections to ensure they are properly seated. You also did not say what the two loose wires were for Is it possible that one or both of them could be the cause.
Ok so I think I was looking at the accessory fuses. I finally found the main fuse box and the 1st one I pulled was a 30 amp that is broke. I didn't check any of the others figure I will just buy some of each and will keep you guys posted.
