Nightman06
- Tuftonboro NH
- 242 Limited E-Series
Hey all, first off, I appreciate any/all help provided. I spend a ton of time reading through this forum and as you can probably tell, little time posting. Trying to keep the clutter down. That being said, I would like some help with my particular setup and some guidance.
I have a '19 242 Limited SE with Cobra Jet Steering, Impros Solas 14/23 twin Impellers, Impros SS wear rings and SHO Lucky 13 cones.
Bottom line up front: Boat pulls to port at all power settings once on plane.
Stage One: Cobra Jet. Nice upgrade, no impact to directional dependance. Everything was adjusted to ensure proper line-up at time of install. Checked again after L13 install.
Stage Two (just installed and run for the first time, yesterday): Impellers / Lucky 13. I am running Blue/Red/Gold on the Port and Red on the Stbd. Port motor shows ~100 rpm less at WOT. I'm getting consistent 45 mph on the screen (1 person, full bag of gas, no top, flat water, no wind) but with a fair amount of starboard steering pressure to stay straight. Hole shot is fantastic, no cavitation. I sealed all housing connections with gasket maker.
I would like to see 46-47 and get rid of the directional pull. Standing by for thoughts. I'm assuming this will come down to L13 ring changes but I'm not sure which to add/pull.
Thanks!
Thanks!
