KXCam22
- Kamloops BC
A warning. This situation is extremely rare but has the potential to happen at any ones house. I just came in from troubleshooting a neighbors house. He was getting an electrical shock from touching his chain link fence and his outside hose faucet. I could measure 60VAC from the gate post to my multi-meter probe unscientifically stuck in the dirt. WTF. I measured his hose faucet at 51VAC to the dirt. Again WTF. I suspected a bad house ground but the ground wire to the copper piping was intact and the hose faucet was actually grounded. Double WTF. That indicated that the dirt itself was at 51VAC, caused by stray voltage in the ground. Measuring grounded faucet to chain link gate got me 110VAC. Yikes!!!. We searched for sources of AC power (like old xmas lites) to the fence but found nothing. The voltage dropped as we worked down the fence away from the gate. 50' away it was about 20VAC. I was stumped and about to call the utility company. I quized the neighbor and found he had an extension cord hanging on the chain link fence on the opposite side of his yard, 50' away to charge the batteries in his trailer. Sure enough, that fence had 40VAC on it. The best part is, unplugging that old extension cord made the stray voltage go away! What is most interesting is that the stray voltage that was being put into the ground on one side of his yard, was travelling under his house and showing up on the other side of the yard. It was not travelling the perimeter of the yard on the fence. This cord was also plugged into a GFCI receptacle that should not have let this occur. I inspected the cord and there were no bare wires touching the fence, just voltage leaking though the lousy cheap insulation of the cord. Buy good extension cords and replace them often if they sit outside in the sun. Don't run electrical cords through your chain link fence unless you buy a super SOW type cord. Hope this helps someone. Cam
