How is the Spare Tire Attached to a MFI trailer with the basket rack under the bow?
kthrash
Madison, MS
My new to me 242LS came on a MFI trailer with the basket rack for the spare.. however it did not come with the mounting hardware, if anyone has this trailer / set up can you tell me what parts/pieces are used to secure the tire to the trailer?
There should be a "J-shaped" bolt that goes through that hole and a lug nut holding it tight to the tire (nut on top of tire). The tire sits in like so... (see pic)boat 2.jpg
I will post a pic of my setup when I get home.
Here you go, top and bottom views. FYI the orange item is a wheel lock.
Of you can't find a similar shaped bolt I suggest you contact mfi directly they are sure to have one and it is probably cheaper than the cost to ship it to you.
thanks..
Another alternative would be to buy a galvanized bolt from Home Depot and drill the end so you can put a lock through it.
